how wide will your trucks be? i tried carvons and they were going to rub at 107mm
Heres the information from TB.
you might need a backup plan!
might be doable with some risers, the setup is really wide
i tried a half inch riser, it wasnāt going to work
I guess you would need to test if you get wheelbite under real riding conditions
yeah, maybe some harder bushings too
Great. I donāt have a back up plan. Lol
They are 105mm on the TB218. Front 15mm riser Rear 11-22mm riser (8 degrees).
Definitely no wheelbite (not even on full lean)ā¦ maybe I can go a little bit deeper to 12mm, but I donāt care.
I make some pictures tomorrow!
Man if thereās a way to make these work with my v4 SD-Rās, that would be so awesome.
So there are a few options, none work?
- smaller wheels
- tighten trucks, play with bushings and washers
- hella riser (Iāve had 1.5" or more on pumping setups)
- grind out wheel wells with sandpaper wrapped around wheels
Anyone willing to sell their Haya to me
May be willing to trade for my Freeride Recurve.
do you think g-bomb brackets would work on this?
http://www.gbomblongboards.com/push.html#!prettyPhoto[gallery2]/1/
They would*, one of my friends had the same idea. the CNCād area is wide enough to mount it, would be a cool deck for sure
*Edit: lets wait till @deucesdown tests it first
I have some gbomb brackets. Can test when deck arrives.
i have them as well. iāll stick them on this afternoon
Those look sick. I want one just for the look lol.
Iām thinking itās gonna be wack. The wheelbase will be so big. Post photos!
here the TB218 with the airless 105mm wheelsā¦ full body weight on one sideā¦
