if you want an immediate and solid solution to the ride comfort on a stiffer deck you could go for pneumatics. the Haya deck should be able to run 6-6.5" pneumatics just fine
Lid can be countersunk more so that the bolts don’t stand out at all. Also the bolts in the pic have a quite wide head.
Hope you can appreciate the mellow radial concave.
Plexiglas pics will come later.
Edit: The actual lid will be cut in 3 pieces as already mentioned.
Edit**: Also forgot to mention that the hole on the ends (centered) is not gonna be in any production board.
Wow that is a very nice piece of craftsmanship was curious do you have pictures of a deck with internals? Battery, esc, etc… also would modification of the internal stringer be necessary for dual esc? If so how much integrity would be compromised? Just thinking ahead for mounting a Unity dual drive.
Really like the channel and porting for phase wires. This board would be so stealth with @hummie hubs or Carvon etc…
You will get plenty of axle walk/torque steer-braking with that style of truck.
That is why Ollin use ronin trucks, maybe a rogue might work as well. Ultimately if you ride it like that I think you will find you want more from the handling
