Selling a halo board carbon fiber deck. I was originally going to use it to build an other board when I removed the stock electronics and to put in better components. However I’ve decided to move on to a different project.
Looking to get about $160 for it.
The deck is missing 4x M4 counter sunk screws for the ESC/electronics plate that I can’t find at my place. It uses the same screws as the top plate. The rest of the hardware is included.
I will also include Surf Rodz TPK 177m machined green trucks - in great condition. It is also missing 2 nuts and 2 spacers that I happened to misplace. Those are pretty easy to get. I would recommend running Zealous bearings as they include the spacers.
Located in SF Bay Area, will ship only in United States as I do not want to deal with customs and international shipping (unless you can pay extra and help me out with the complexities).
I would like something like this but I am unsure as to the max size of battery you could fit into that cavity…Hoping to put a 10s5p or even 12s4p…? Is that unrealistic do you think?
The deck supports a 10s3p configuration with BMS. Here’s a photo of the batteries it used as well as the stock inside as a reference. You can easily fit a Unity or 2 VESCs in there without issue. On the rear where the motor phase wires come out, is a spot for a charger port and power switch (go with anti-spark).
Battery dimensions are:
Dimensions: 330mm x 140mm x 20.5mm (LxWxH)
The deck has a little bit less space as the Enertion Raptor 1 lengthwise, but also 6mm depth-wise.
From the looks of it, a 10s4p can be fitted. It will be a really tight squeeze.
If you do that, I would bypass the BMS for discharge and somehow place it between 2 VESCs as a small BMS will fit. Recommended to look for 4-5A charge, which are small.
If you use a dual VESC or Unity, it may be hard to fit the BMS in. I’ll leave it to you guys for your build.
The 5th post has a tear down of the battery for your reference.
Could you please let me know your set up to fit 10s4p to haloboard deck. I’m also a haloboard deck user and my battery builder cant find a way to to fit larger than 10s3p.
hmm Weird, length is enough for me, for a flat 10s4p (even got a little room), the problem was height, which I fixed by using some dense foam on the side to support the weight on the side, not the battery
