I havenāt logged on in FOREVER! Things got complicated with the job and I had to relocate to North Carolina. I havenāt had a chance to play with anything ESK8 related in over a year now!
Iām in Charlotte
peopleās engagement here
Good that some of us not averageā¦
Also interactions like these
It finishes with āthis forumā which I laughed at a littleā¦
Well that went from 0-100 in less than 24hours
Whatās his problem?
I assumed he feels that the price was too high for the goods he was asking about. But that response at 7 in the amā¦ Because you know, transparentcy this was my response:
āOh man! Spicy. Word or two of advise there teen 'stache. Even when you arenāt happy with the way an interaction goes, try to be friendly/ adult like and donāt burn bridges. People have been departing this forum legitimate, and precisely because of behavior like this. Good luck withā¦whatever it is you do/build.ā
by the by good sirā¦paying homage in my HAYA board soon.
+20% range, - 10% give a damn
I am pretty sure my pee pee grew like an inch using those PCBs.
A very welcome side effect.
Hi I donāt really know how to start a thread. But could you guy answer my question. Iām looking to build a single belt drive longboard using a 6384 200kv motor with a flipsky mini vesc. The thing is i live in Australia and li-on batteries are expensive and LiPo batteries are annoying. I have a couple 18v 4 ah Ryobi batteries lying around and i was wondering if they would work if i put 2 in series. Iām concered about the discharge rate though.
Lots of people have done batteries with drills. Just takes up a lot of space and might not look the best. Just make sure your battery cutoff and current limit values are set right when you set up your vesc.I think 2 of those in series would be like 10s?
I donāt know the cells but youāre right. Discharge probably wonāt be great. Solve that with more drill batteries lol.
the short answer is it might not work
the long answer is it will if you know what youāre doing.
The first question would be are the packs fully identical? Has one been used longer than the other? how will you monitor the pack voltage etc? how many amps can it handle?
batteries are batteries but have you an answer for those questions?
