Is this for V2?
Yes, designed for the V2
@ElskerShadow Most excellent build indeed my good Sir! I am in the process of moding my carbon GT from the core out. If I could may I ask what more pulley you used/where you got it from?
Finishing the build today ! Just my antispark is not working @FluffyllamaZ I used generic 15t pulley
Iām back in GER. Posting another one today.
Not to quick my friend ! Iāll PM you I need something more !
get rid of antispark, i blow up mine to and use an XT90s. more reliable. did you plan to use a BMS ?
Are you guys discharging via BMS? I am on a similar build and not so sure what to use. Iād like to keep the on/off button and not using a loop key ā¦
I will not use a BMS thereās definitely not enough space in the end. I actually like to have a push button.But I donāt necessarily think itās a bad thing. If the battery is properly checked after everything should be fine I have yet to try XT90s ! How it is ? Itās like a loop key but without the spark ? I am eager for integrated antisparkā¦
nope, using external BMS only to charge you can try to use a vedder antispark, but with a 4P lot of people reports (including me, problems) Hopefully i hope weāll see more reliable switch
yes, loop key with an XT90S (antispark)
Are you based in Germany Frankfurt area? I think I saw u today
Nope Iām in France !
yeah this winter I plan to swap out all the electronics in my CGT. I want a 12s7p with some 6374ās maybe a unityā¦but that FSESC 6 6 is also looking good. Iām a big guy so I need the power/range. Iām about 240 Iāll probably be about 230 by summer if I continue at this rate.
Focbox or unity will do well with your size. Your limited on your battery size with a carbon GT. A GTX you can add a printed riser and go big on the battery. 10s5p
with room for a 10s7p or a 12s6p and only 5/8 increase in drop on the enclosure. No deck material needs to be removed.
bro i wouldnāt call this a perfect clone, its way better than a GTX. aesthetically and spec wise.
I know itās an old post but iām thinking about doing it tooā¦ how much room in total do you have under the board to fit everything? what battery did you use and for how much range did it last?
i would also like to know
Without a spacer, 10s4p with a small BMS plus VESCs for Unity. Youāll need to get creative with space and youāll need to remove a bit of timber from the deck where the VESCs will sit.
