Why does your rear mounts and wheels look not streight or is that just fish eye effect in your pictures? Looks like you might need spacers to even everything out?
Itās an illusion the belts AR enot really aligned but the rest is perfectly
Ye those belts look on a mad angleā¦ as long as it works thoā¦
If you need a micro bms you could use @Deckozās micro bms from his evo build. I think itās for 13s but you can just drop the last 3 leads and it will function like a 10s bms.
Beautiful build man, I wish mine turned out like this
Better off getting a micro BMS for 10s like
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F282923151393
FYI I have put micro BMS links in all my build threads for 10/12/13s
Unfortunately the sellers wont ship to france and I canāt find the same BMSās on the french website
I found this ones that look rather small: 60358mm
i will add more if I find them
@ElskerShadow : Is it that you managed to get everything in the box? For my part, itās a real nightmare to manage to get everything inside, even without BMS, I find it hard to find room for the switch anti spark ā¦
Dang thatās not great news! I will not be using BMs either in the end, my take on this is removing as much wire as possible and use bullet connectors instead of XT90/60 Itās either that or adding a little height with some sort of gasket @Toleg
Bullet instead X90, definitly a good idea ! will do that too. Iāve found a .stl to add more height, but i want the slimest case as possible.
but i strongly recommend that you keep the balance wire in your pack, event you didnāt use a BMS. Youāll have to check sometimes if you have no drift on your cells.
Yeah donāt worry itās anticipated! I will check voltage drift every 200 km Shouldnāt be any issues with quality cells
May I ask what sort of paint you used for the top of the deck, I love the colour and hexagon pattern so much Iām going to copy it
I used spray industrial paint Black matte
Thanks mate!
I 3D printed a extra distance on the hatch, so I got extra storage underneath my focboxes to fit a BMS there. + I added some rubber around my enclosure since I wanted to avoid routing the deck.( I have the normal bamboo GT deck. )
its so nice to ride on
Do you have pictures?
Not sure, will have to check
edit: have a video from when I was āprototypingā it
