Hello everyone! This is my first post and this is my first eskate build. I been researching for the past few weeks trying to figure out the best way about this. First, I just want to say this forum and its users have been a tremendous amount of help and has really propelled me along on my research. I’ve all but narrowed down to the last few pieces to what I think I want and want to make sure everything is compatible. As I don’t have a deep background on skating in general, I do believe I’ll need some help. I’ve skated a little bit before, but mostly for commute purposes and never even owned a longboard (just a normal popsicle board and a penny board). My reasoning for building an electric skateboard is because I want a different way to commute to work and because I do enjoy building and making things. I don’t have a set speed or range in mind. I don’t really have a set budget either but I’m not necessarily tying to get the most expensive pieces on everything and break the bank. If a better build would require me to upgrade, that’s fine. I don’t mind saving up a bit more. I plan on buying a lot of the parts as I go along rather than trying to save up and buy at once. I have already bought the deck and it is in the mail.
Deck - used Earthwing SuperGlider 38" x 9.5"
Trucks - Caliber II 184mm 50°
Wheels - ABEC 11 90mm Refly Flywheels
Motors - TorqueBoard 6355 190kV x2
Mount - mounts from buildkitboard x2 *link provided by moon.
*Belt and Pulley - TorqueBoard 36T ABEC pulley 12mm combo kit x2
VESC - FocBox Unity ESC
Battery - going to assemble myself but plan on 10s4p w/ Samsung 30Q 18650 battery cells
*Remote - DIY remote from fellow user solidgeek.
Okay, this is what I got thus far and I will try to delve into it a bit more for clarity. The parts with asterisk beside them are not hard locks yet, but I am open to any ideas on anything really. I ordered a used SuperGlider online because I was convinced on here they were good and they have been discontinued but I really really wanted a longboard with a kicktail. I originally wanted to get dual 6374 motors but I came to realize that I would be pushing for space and didn’t want to get 218mm trucks because I was worried it might look a little too wide and thus weird. I’m not too sure, but I’ve come to terms with 6354 and I’m sure they will be more than enough. The hills here are fairly tame here and this is my first build. I was just more worried about heat. I’m not sure on the belt and pulley kit. There’s a 36T and a 40T. I haven’t done the math yet when it comes to the electrical and mechanical system yet but I’ll get there. I will be acquiring a spot welder but I want to build my own battery pack. I’ll figure out details on that when it comes to it but I’m not sure yet if it will need to be 12s4p or a series of 10 is fine. I guess when I narrow down the VESC, I’ll know the answer to that. Or maybe what VESC I have won’t matter for what my battery setup will need to be. I plan on using LG HG2 which seems to be one of the better Lithium-ion on the market, but I’m not 100% certain because a lot of what I been reading up on hasn’t been very recent. I will say I am NOT down for LiPo and am certain I want Li-ion. The VESC is what is really giving me a lot of trouble. I really don’t know what to go for. Even after all my research, I am not that much closer to really knowing what I want to get. I want a high quality one but also don’t want to wait an undisclosed amount of time for them either.
Those are the main components that I have figured out. Of course there are misc items too. I will get a battery indicator, riser pads, and I will make my own enclosure. Is everything thus far compatible with each other? Am I missing an important detail or part that I probably should have? Should I post links of the items I have listed for simplicity sake or is that unnecessary?
I can take pictures and record my journey on this if that would be interesting at all. I want to thank you for taking the time to read this.
Edit- Switched up my parts list to update comment suggestions. LG HE4 --> 30Q. Note, I do plan on thoroughly researching this battery building process. SK 6354-260kV --> Torque Board’s 6355-190kV. I was sold on a Unity. Now I won’t need to buy a power switch. I may need to change remotes for compatibility. Nano --> DIY arduino based remote. This thing looks perfect for what I originally wanted. Small, sleek, boosted remote inspired, and no hobby remote trigger. I’m still reading the thread and figuring the details out. AFAIK, this should work and since I’m doing my own battery pack, this isn’t too much extra.
