I also have tracker dart 219 Black and torque diy 218 but both a touch wide ca V4 TD
That what I was thinking. Maybe do away with the inside spacer, trim 1/2 in off the axle on both sides and rethread the axle in both sides?
That would look the nicest, and remain RKP unlike tracker dart (which though has old school cred)
The Evolve Supercarve trucks are also 305mm axles
Are the TD 305mm? That’s what I think the SpeedDrive will be
This also increases the moment arm on the unsupported axle and could be problematic.
@joeadams101 do you have a wireing schematic for the I pin connectors that come on the be TorqueDrives? I can’t seem to find one anywhere.
Another reason I went with 50mm!
It looked to be about 11.5 in when I measured with a tape measure yesterday. I’ll measure with a straight edge tomorrow when I get back to the shop.
You can get online google Higo connector. I don’t have mine handy but these are the sensor wires to focbox, this color matching worked. Though I dropped the temp wire. Just match the standard sensor wire color scheme on right to V4 TD wires in the left, in absence of pinout.
Course that won’t tell you which wires are which back to the motor
I appreciate it brother, I can prolly figure it out from that Info
Green, blue,yellow-hall Red-5v,blk-gnd Wht- temp, optional
I’m sure I read about this somewhere but I can’t find a definitive answer. Running the Carvons unsensored? Opinions? Experience?
Yes optional. I ran mine with sensor wires disconnected for a while. No problem for about 40 miles or so before I finally pugged then in
Thanks man! what differences have you noticed between the two?
Nothing it’s just starting with a kick off vs without to me.
Those are 20A rated… EDIT: my bad, those are 15A AC / 2A DC
