just wondering if any one could identify what type of pinion gear this is, its has 15 teeth
Also if any one could identify this gear on the trampa wheel - it has 70 teeth
also does any one know anywhere i could get hall sensor wire “extenders” - I want to move my ESC to the center box and the cables are not long enough. I will make some if i must.
hi @mmaner ! maybe you help me here, Does THe torque esc sensor wire ar ejust to make your sensor wire longer ??
if YES , do you think it will fit with the unity ?? they look like normal hall sensor wire…
