First build! Coming from a boosted, I wanted to get tires and bindings so I feel more “secure” especially on the roads of NYC. I could get a Kaly but I figured if I’m spending that much money I could instead invest in learning how to build one. Plus when you DIY, “you are the warrranty.”
Let me know if I’m doing/about to do any rookie mistakes!
Parts list:
Trampa Infinity with HS11 deck, bindings, 8 inch tires
Fatboy Focbox case in red + dual Focbox
Fatboy 5:1 direct drive
SK8 192kv sensored
Bestech BMS
Firefly remote
Custom grip tape job while I wait for other parts. I wanted to differentiate myself from the usual hexagon grip tape patterns I see on the Kaly’s here in NYC.
Because of slight variations on trampa’s manufacturing, one side of the axle is slightly fatter than the other so the drive baseplate doesn’t go all the way in. Notice in the picture that there isn’t enough space for another bearing, let alone the nut. I had to use a hammer to forcefully slide the baseplate in.
Got the direct drive and motors. Really need to do something about that sk8 blue. Anyone have ideas on how to tone it down/black it out without affecting heat dispersion?
@never4getf150forums I’m considering that, but I’m afraid of removing too much material and damaging the shell. Also weight differences might occur and could potentially affect the motors rotational stability. That or I’m just worrying too much
@JonathanLau1983 that’s the easiest and safest solution for sure. It’s more controlled compared to using spray paint, and it dries quickly.
