Bought this brand new and was going to use it for a build but went a different direction.
Only had ronins mounted up to it for a little bit to try it around the block. I did shave the grip tape as I didn’t like the overhangs where the feet are positioned.
The indents in the grip tape were from the Loaded pan head hardware (highly recommend). Board is otherwise in great condition.
$170 shipped
LONGBOARD SPECS
Length: 33” / 84 cm Width: 9.5” / 24 cm Wheelbase: 24.5” and 26” / 62.2 cm and 66 cm Tail: 7.25” / 18.4 cm (tip to inner bolt on 24.5” wheelbase) Concave: 0.30” / 0.76 cm (at W peak), 0.39” / 0.99 cm (at W trough) Rocker: 0.33” / 0.84 cm Wedging angle: 3.5° Weight: 4.0 lbs / 1.8 kg (with grip)
