Wow, this is awesome, cant wait to get hand on these Configuration options puts VESC into shame Also will probably make some heatsink for this stuff as I will be pulling some amps
Trust me today I canāt even walk my legs hurtā¦ That torque is sick like all the time it tries to take off
Thatās what she said
Itās almost here
So with these controllers, one could build a 4wd, with +80mm motors, absurd gearing like 15:30, on 110 wheels and still have loads of torque?
80mm wheels on 110 wheels will not have much clearance or etc
Donāt know if @mmaner or @longhairedboy have yet tested them but I have run into some configuration issues Hardware wise it is really solid and nice looking product Have to get some extra JWPF connectors so I could get this into sensored mode
@jayx is building a test rig for them now with some old li-ion 26650s of unknown chemistry, probably ICR, maybe INR, who knows. Itās gonna be a real rat rod scrappy scrapper.
Follow his build on https://www.instagram.com/theonlykindajake/
Based on what iāve seen, itās nothing like vesc tool and its kind of weird. The entire package is nothing weāre used to. Also, no 13S. 12S MAX.
The plan is to drag race them if they work out because theyāre allegedly so awesome and can take so much powah. Weāll see about that shit, son.
Then iāll take it to Colorado and get @Lunasi and @MoeStooge to race on it because i want to see that.
Colorado needs a Pikes peak Raceā¦
Only fair to state you were using outdated firmware.
Well if it was major or at least minor version release yeah I could say its firmware issue
But I will try this weekend again Biggest concern are motor out of sync as they spin at different speeds and braking issues.
So far weāve just been putting every release out as a new patch release number. Donāt take this to mean the changes are trivial. Iām not sure itās going to fix all your problems, but itās a good place to start at least.
If the different speed youāre talking about is whatās in that video in your other post where the motors arenāt always in speed-sync, donāt worry about that unless you actually feel it when riding. Since the Arc drive is a true torque-mode controller as you have it configured, it takes almost no current to spin up the motor with no mechanical load on the wheel. This means tiny little tolerance offsets in the current sensors, throttle PWM/analog sensors, etc. add up to tiny differences in current commands. With such little mechanical load, you see this when thereās no load on the motor. For example if one ESC is seeing a 1A command, it might spin up while if the other ESC has a 0.5% tolerance difference on command, out of 200A full range it might be reading 0A command at the same time. The 1A motor will spool up while the 0A motor is still sitting still. Once you ride it, you no longer notice this because current commands are much higher.
The braking issues are my biggest concern that we need to get fixed as the top priority, then see where youāre at on ride quality.
was just texting jake about the ARC units we haveā¦ he sent me this. I thought it was interesting. Iām the blue bubbles.
What about the CAN? I have made a cable but I couldnāt find anything related that apart input type. It was shown in video of setup but I canāt find it.
@christensent Normally I donāt run FOC, if I do its only hybrid mode. I donāt mind the sound and with the VESC I donāt see any benefit to FOC at higher RPMās and there is a significant hardware stress issue.
Iām just waiting on an enclosure to get mine up and running. My tentative setup is sensorless. Should I order a 2nd fly lead for sensored operation and can cable or is this good enough?
we couldnāt find the CAN bus either. Also, motor detectionis somethign called āautotuneā which of course only makes me think of hit singles by Cher.
You will see CAN options when you install the latest firmware. I just confirmed it is in v1.1.5.
@mmaner Arc is always FOC in all operating modes and states, so thereās no need to select or worry about what mode itās in.
In our internal testing, most people have been quite happy with sensorless performance. Itās not perfect and if you want full starting torque from a stop up a steep hill, youāre going to need sensors. If you get the board up to even a crawl speed it will pick up sensorless no problem, and on flat ground jitter-start will usually start a vehicle from a stop (when optimized for your vehicleā¦ it takes some trial and error to get the right jitter settings, with the default jitter start settings it often wonāt really start a vehicle sensorless without giving it a kick to start moving).
