Hey guys,
I’m using the Unity on my Mountainboard Build and almost suffered a horrible crash today because of a sudden cutout at hard accelerating like @mackann told.
I guess I almost had 45km/h+ on the clock so it did occur quite late. But yeah threw me off almost, glad I hat my bindings…
Also I have these stutters when full accelerating from a dead stop sometimes.
My settings are:
Motor Max 80A
Battery Max 60A
Motor Min -60A
Battery Min -30A
So I guess the settings are quite conservative.
Does anyone have found out more about these problems?
I’m a bit scared now to try again and try to reproduce the error…
lol yes, always good to start with the basics though. I ended up contacting Enertion support through the site. I think the usb-c connector is bad. Hopefully they will take care of it. The box had one noticeable dent in it so maybe it’s USPS’s doing
Tbh I would have to double check that. But I don’t believe so. In the FOCBOX tool only COM 1 shows up and gives the error “Cannot read firmware. Please make sure port is assigned to focbox” or something like that.
I’d double check, if a device shows up but says something like “unrecognized” it can just be a driver issue. If no device shows up at all then it’s probably a faulty port. But every unity is connected through USB twice before passing QC so it shouldn’t be possible unless your box was absolutely crushed by something.
Hey, don’t be too hard on yourself! This is a great product, going through the guided setup was very painless. I actually crashed last week (got hit by a car) so I have plenty of time to have it resolved. I already chatted with support and sent them a video as per their request this morning. Thank you Jeffery, your help is deeply appreciated.
Anything else I should do?
EDIT: I just wanted to clarify that I have not used the Unity other than setting up and bench testing. I re-read my post and saw that it wasn’t clear. Forgive me for any confusion that might of caused.
Thanks for your effort! I like the Unity quite much, I already ordered a second one for another build. I hope it is not a hardware issue as it seems not occurring at every user.
Here are my settings:
I’m running two Turnigy SK8 6374 192 kV motors. And I am on 12S not 10 like in the picture…
Unfortunately I wasn’t able to check the faults as I am an iPhone user and it turned itself off till I was home… Maybe I can reproduce this behavior by pushing a car away or so…
Erm xt 90 is not needed 4mm bullets are also overated you will almost never discharge enough amps to cause damage to the stock config that’s why enertion does not ship it that way and also because they use the stock config for the raptor
