What size drill bit do I need for the unity power button?
1/2" or 12-13 mm bit should work.
Cheers, 12mm did it
Can I use a single soft on/off switch to control two unity’s? I know you can for latching switches on other ESCs.
I’d like to try some thing new instead of loopkeys.
I think @Deodand answered this somewhere, but I’m failing at finding it.
Yeah, check out my build thread ( https://www.electric-skateboard.builders/t/the-saw-r-spec-drive-4wd-dual-unity-haya-12s4p-97mm/81220/94?u=blasto)
Basically on the CAN bus, wire a 20 ohm resistor in series with the 5V.
Set one as master other slave. Master has switch and ppm input.
Master will send a shutdown command when shutting down, that will also power down slave
@Blasto @Mikenopolis thanks.
Any idea if there is anyway to do this without canbus? I’m using two receivers.
Not trying to get on canbus train just yet.
I guess you could use a SPDT momentary switch.
Two receivers? You mean you split the signal on one?
Anybody want to go in on the bundle sale going on right now? $300 for one, or $200 for 2 or more. If anyone else is already doing this, let me know where!
Any updates on this?
Where are you located? Im in BC, Canada
I’m located in Portland, OR. I actually ordered two of them on Sunday. Do you want to buy one of them?
Sure. I will DM you. Or add me on Facebook?
@Deodand Are there plans for “Rider modes” or custom profiles?
Could I also suggest adding the eRPM limit parameter to the FOCBOX APP?
Yes to all of these
Anybody got the 3the batch already? Ordered 15 march still waiting…
Latest information about the 3rd batch shipment is here https://mailchi.mp/enertionboards/enertion-newsflash-june-6-2019
Glad I ordered on April 1st for April May June July* shipping
