decrease motor max. you may have to decrease battery max too depending on value
Motor is 80, batt is 30, what should I switch them to?
try motor max 50 or 60
Leave batt at 30?
yep that’s fine
I will change settings when I have my pc tonight, I’ll let you know what I think, but thanks:)
I put my
motor max 40a motor min -20 Batt max 30 batt min -6 absolute max 130
These settings calmed it down quite a bit. I like how I can hit full brake and ride the brake going downhill or slowing down. Do these seem ok? should I change anything? Thanks!
Sounds good, just adjust as necessary. I’d raise the battery Regen myself.
Back to -12?
yep, if you’re running 3p
What if I am running 4p?
What cells? I use -16 on my 4p pack.
I have space 3 and 4…
yea -12 for the 3 and -16 for the 4
hey, im haveing trouble with my first build, 6374 192kv 12s2p and a 4.12 vesc it turns on okay but when i press throotle motor will jolt then vesc turns off please help
Do your motor detection and ppm adjustments and you should be good
Annoyingly I’ve actually done that , but I’ll try again , is fix more dangerous then bldc on vesc tool
