You mean abec?
Yep or apparently the stupid clone wheels I have
, i donāt have it.
Right! Well probably with heat shrink is gonna work also on original core.
I want to buy the original abec, but i donāt like the green , but if i go with the black one, Then iāll have another black (boring) . Think about the red metroboardā¦hmmm
Otherwise buy a cheap clone with small spokes for testing. I got mine from diyeboard
The pulley Will use this japan bearing, NSK F608ZZ.
What the bearings? The company? NSK are one of the best but itās very easy to buy fakes
Yes the bearings. I see the brand is the same. So thatās why my question.
So are these probably all fakes? https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20181001042422&SearchText=nsk+bearing
Yeah the brand is very good. And I am not doubting xtla is buying fakes. Iām just bringing up a problem that someone might not be aware of
Yeah Iād say so, thereās probably a good amount of legit sellers in Europe so I wouldnāt worry.
Actually iām not sure if its genuine or not, it cost me like 4$/pcs, The quality looks good tho. Then how do we know if itās genuine or not. The seller stated made in sweden
Ok here goes.
If itās cheaper than the cost of what the legitimate bearings cost then itās probably fake. I havenāt searched this bearing yet but Iām pretty sure NSK can check if your bearings are legit if you send them pictures.
But it probably doesnāt matter that much because you are prototyping
Will check about them, thank you for pointing this out!
Also, NSK make their bearings in japan. And Iām not sure if they make it anywhere else
You could avoid needing bearings altogether if the insert was slightly longer, and used a retaining washer and three screws - a la APSās pulley design. Food for thought.
Yea, if look at the picture it shown japan, but the bearings shipping from china, for the cost they are higher then the aliexpress. Iām not sure why they stated made in sweden and im about to ask them. Hell yea ā¦
