ughghhhhh heeebie geeebies. i just had two non-wisdom teeth pulled after not going to the dentist for 14 years! luckily theyre still way back there and its not a new look.
A dry socket sucks so much. Gives you bad breath that smells like death because basically your jaw bone is exposed at that spot. Sometimes a dry socket cannot heal on it’s own because it’s so exposed…
Yeah it’s really bad. Worse than 5mins after the extraction bad.
Do you have a recommendation for a switch? I have antispark Xt90’s I use but I’d prefer a switch inline as well.
im not even sure what voltage is needed but i heard 12v might be good enough but 24 is better. i’ll look into it.
Ok thanks Hummie
Almost any switch will do 240v to 12v but told should add a resistor .I’ll post a pic soon today.
Do you even need to use the power switch on these? What if have an anti-spark power switch (on the battery) before the xt-90 in?
I don’t think you need a switch. but if you do or don’t use one theres a solder connection that need be made or broken. forget the details but someone here should know or on their site
And you’d probably need to do this to both on a dual setup. Seems like there should be an easier way though.
edit: yea these don’t have the switch connector, it’s already soldered. Perfect for the battery I have which already has an anti spark switch.
lol just check the picture I posted
if you bought the one that doesnt come with the switch (this groupbuy), the 3 pin connector for the switch is missing and instead theres a solder joining 2 of the 3 pads to permanently turn switch on. The idea is you can attach your own switch later on if you desire.
On a dual set up, I would do a Y- splitter and skip a red wire connection on one of the VESC, so the LED only draw power from one of them.
So good news and bad news. The good news is that properly wired the onboard anti-spark switch does work. It even works if you double two up on the same switch.
The bad news is that firmware update through VESC tool does not work (at least did not work for me the 5 or so times I tried it). Interestingly one of my Flipsky’s came with 3.38 and the other with 3.40. I thought updating would be cake, but it wasn’t.
I was going to try to program it with my STLink but the pinout is different on this board than the 4.12 so I’ll have to wire a new connector.
If someone can check me on flashing from VESC tool that would be great.
Lastly, fair warning, it appears as though they’ve split the binaries. 3.40 for the 4.12 is not the same as 3.40 for the 60 even though the filename is exactly the same.
Ok, just one more thing - there appears to be firmware out there for hardware 7.5. Anyone?
Thanks,
All FSESC will be shipped with latest firmware version, Can you try this linking for correct update your firmware (tutorial) please? For firmware, FSESC series all use the unlimited current 3.40 firmware for bigger current except orginal standard FSESC4.12. Pls feel freely contact us for any help you want. Service email: [email protected]
I’m a total noob to group buys so be gentle.
Do I simply send $120 to the PayPal mentioned in the original post and throw my info into the spreadsheet to get this?
No worries! Yes thats basically it but before you transfer via Paypal, I suggest you reach out to @hummie and ask if there are any spares on this batch that you can get. You can select Friends & Fam or seller option(for a higher fee from paypal) but I trust @hummie and paid him via F&F which is fine but generally not encouraged throughout the forum for several reasons.
Let me know how else i can help!
Right on @Wraith I appreciate the helpful response. I’ve been reading through the vast majority of the comments in this thread and just now learned what people meant by F&F (thanks to you)
I can also see that he’s reliable and well trusted around these parts! Nice to see good people still exist.
@Hummie do you have any more of these available in this batch? I’d love to grab one!
Yeah you can check
if you want a list to consult for verifying well accepted builders and sellers. If you happen to miss out there’s another GB of this same vesc that @hummie started a few days ago too.
Edit: You can Give him an upvote once you get your unit as well as it does help
Have you tried to install the bootloader? Sounds like the bootloader is missing.
Are you sure you are using 75_300 version? Because it differs from vesc6 voltage divider values, differs and other values and functionality also differs…
