hey guys.
Want to share my battery experience with you to:
help (read confuse) others, who cannot decide on BMS usage
collect opinions about what actually happened to my battery over last 2 years
Trying to be short. This is how it was in chronological order:
~ end of 2016 I bought 40x Samsung 25r from reliable source for my Fliess1. Each was perfectly 3.53V. Of course I opted for BMS-free solution and made 10s4p out of them
happy riding maybe 500-700km. 70A battery limit
~ mid of 2017 I bought another 10x Samsung 25r from the same source. To mix 'em with existing 10s4p battery and make 10s5p for my Fliess3, Fliess3FL, Fliess3Bulletproof. Of course I made sure to distribute them equally and even the voltage up in parallels as well as in series
happy riding another 1000km+. 80A battery limit
~ end of 2018 while riding I felt a sudden loss of power, and after another several km got âdisconnectedâ. Since it was already Nov I decided to put Fliess3 on a shelve and investigate the battery later. Although I knew it could be fatal for the battery, but I convinced myself that it was just a broken/bad connection
Feb 2019 I fetched the battery and got surprised to see 1 bank (#2 on the picture) totally dead (infinite resistance) and #10 almost dead (see pic). However the voltage distribution right after opening was almost perfect
I find it strange that despite on gradual and very predictable degradation over ~2 years, I suddenly got a battery in such poor condition. Yet before the last ride, I managed to achieve expected 22-25km of ride.
Any ideas guys what has actually happened and in which order?
@Bor.inc this time itâs very prosaic StillâŚI really wish to understand what exactly happened to the battery to avoid such things happening again in the future. Would BMS prevent this shit?! I doubt⌠But would definitely be safer.
Perhaps you reached the end of life cycle of some of your original cells? I think you are supposed to get 300 to 500 cycles, or about 2 years depending on how you use them.
Well the BMS balances the cells ofcourse and maybe (I have like no clue on this topic btw) the 10 new cells you bought have a different internal resistance compared to the other pack which could result in something like this?
Edit: if this was the case, a bms could have helped stopping certain cells overdischarging or something
I would think the cells happened to come out of balance on this last ride. Some of the cells got over discharged (thatâs what the power dropped) and then the vesc cut off as they reached very low levels (1v or so).
That same think happened to me a few weeks ago with a Lipo pack. It is now not usable for esk8 so Iâm building a 12s3p 30q pack. This will hopefully stay in balance better and Iâll also be adding a plug for individual cell monitoring instead of just the whole pack
should not be the case. Letâs quickly and very roughly estimate - given I was always able to do at least 20km per charge and that Iâve done letâs say 3000km altogether, we get only 150 charges/discharges. For branded cells it must definitely not be a limit.
I can imagine this to harm only if I made the whole bank from the new cells while keeping the other banks from the old cells. But I didnât. I have added 1 extra cell to each of already existing banks.
even if 1 cell in #2 bank got damaged on the last ride, which caused the whole bank to get unbalanced, it should not have caused its total death. Until 25r behaves very different than 30q when got fully discharged. Once I tested 30q very-very hard, i.e. short circuit (total 0) over multiple days, overcharge, freezing/heating, and I could not get it broken. Without even losing a capacity. Even A123 shown worse than 30q in my hard test. Eventually I managed to kill both by overcharging to 4.7-4.8V (do not remember exactly).
haha, well, it depends very much on high and low end cut-offs you setup when make capacity measurement. I tested discharging 4.2 â 2.9V.
indeed interesting. Was surprised about âAt 4.5C charge and discharge, 20% resistance mismatch reduces lifetime by 40%â. Still my conditions were much softer (only 1 new cell mixed with 4 older) and far from declared lifecycle limits.
as seen from photos, only #2 P group was totally damaged, i.e. each cell in this group has infinite resistance and doesnât react on applied voltage (even relatively high 42V).
again, as I mentioned, when I pulled the battery out and measured each group, they were not discharged (3.8V).
I would think then that the p group came unbalanced and drained too low (below about 2.5v). That is due to not have a bms to balance when charging. Cells come unbalanced during discharge quite often, but itâs usually ok due to being balanced again when charging. Since it wasnât balance charged the cells just got out of hand and some maybe even overcharging making the ir even worse and more likely to unbalanced in discharge
I agree. I think that over time what starts as a small mismatch will escalate. Some packs may eventually overcharge, leading to faster degradation, while others will be well under their threshold which could explain why some packs are in nearly new condition.
Perhaps packs #1,2,9 and 10 also aged faster due to heat?
@pat.speed, @Jumpman I am almost sure my next experiment will be to take 2 brand new cells, one letâs say 3.5V and another 3.8V, connect them serially and run through multiple charges/discharges. After several cycles I will see the tendency. I like a theory and usually trust it, but still prefer to double check on practice
this is what called thinking out of the box! Dude, nice notice, indeed #1, #2, #9 and #10 are those living next to controllers. I barely believe it could have had such big effect but damnâŚthere is correlation
StillâŚwhen I get equal cells and kill them equally, I expect that even without balancing they would show good at least first 150-200 cycles. I am however below that and honestly surprised. If I didnât make my own hard tests on 30q (in the comments above), I would just believe that Li-ions are indeed very sensitive to over-charge/discharge/heat. But I honestly had a hard time to kill it
guys, I really appreciate your opinions and willingness to help me personally or to make community knowledge base better! Dope!
BUT, honestly I never believed in all this BULLSHIT about BMS for branded (read good) li-ion cells. And good that I didnât give up just blindly accepting another theory. For myself I decided - NO BMS in my future builds.
I am sure my problem is not new and if more people just open this boring BMS thread, then someone would definitely know the answer and help. Although I played a lot with individual cells, I never used unbalanced packs for a long time. Thatâs why for me it was new. If anybody still interested what happened to battery, then I will happily explain.
Im certainly interested in what caused all the problems, I before this asumed a BMS is necessairy for a pack to balance but that isnt the case apparently (learned something new! )
No BMS should be fine, provided that the pack is made from similar cells, and in use they are kept at similar temperatures relative to each other.
On top of that it is important not to charge fully, so you could charge to 41V instead of 42V, for 10s. This allows small imbalances not to have such a detrimental effect, for example if a cell is overcharged it may go to 4.15V instead of 4.25V. Likewise raise your low voltage cut off so weaker cells donât dip too low.
One thing to watch out for is that even batteries from the same batch can have a 15% variance in their impedance. Unless you measure your cells, it can be down to chance how quickly your packs get unbalanced.
@Bor.inc all cells in #2 appeared to be just good and even perfectly balanced with the rest.
Protective plate popped up on one of the cells and then (my assumption) on the rest of the group, because overcurrent? I will test.
The same for group #10, but not to the end. Almost sure all cells are good there as well.
In other words, the whole pack (despite being partially mixed) stayed very well balanced during ~2 years (2000km+) and no BMS.
