like the boa ?
Yeah, they should be fairly similar.
100mm is a great size but no point in having two options for 100mm and ultimately for the DD setup 110mm would be better. So we went with the 110mm option.
Diversity of great products is great
@bandrews510 I already have a working prototype using 3 pole double throw 40a relays.
Iām working on a circuit that will shrink the footprint to a pcb and some smd components that will work with NRF24 remotes and a programmable button
Basically the same way a soft switch works for the power on power off on the boards, on instead on on/off it will reterminate on the fly
oh my god. the 110mm kegel style is EXACTLY what we have all been waiting for. so excited!
@torqueboards I may try and get my hands on some 12x22x5 bearings and throw those 160x50 wheels on my MBS Board
@holyman92 They should fit on MBS, Trampa, Evolve as I made them somewhat similar for the rim size. I figured it would be better overall for them to be fairly similar. Tires/Tubes should be pretty interchangeable. Although, I canāt 100% confirm didnāt try yet.
Any idea when you will accept pre orders?
@Mich21050 Once we get them tested. Shouldnāt be too long. Have to make a few changes to the rim. Iām open to making a few more tire styles if anyone is interested. I was thinking of a 7" Off-Road Tire.
Mbs has 12mm axles tho so the only bearings I found are 12x22x5 and from some random site
Whattttt itās almost impossible to get 12x22xX bearings. I had to buy 12x21x5 and make some dodgy ass bushings for them to fit
Courtesy of @torqueboards, he found these: https://www.amazon.com/Bearing-Sealed-12x22x5-Metric-Bearings/dp/B00IK4JYA0 But itās 13$ a pop. So 8 of them would be more than 4 new hubs
holy oof
We can probably get those cheaper. If a lot of people plan on actually using it. Is everyone using it for the same purpose? 12mm axles? Is that Trampa/MBS or just MBS?
trampa uses 12mm for the infinity and vertigo, not the ultimate
For me is MBS, specifically Matrix 2
Yea I will never use trampa but my matrix 2 use 12mm
Cool. IF all else fails you should be able to throw TB tires/tubes on MBS Rims. I think, need to check.
