So basically i want to build a electric longboard (pretty obvious) mainly for commuting. For the motors enclosure and almost everithing else, I was thinking about buying the pre-made kit from diyeboards (this one) because i’ve heard pretty good reviews about it, but any advice is welcome. But there is one problem, I can’t buy the battery because I live in Argentina and customs won’t let them pass. Sooooo i thought about bulding my own 10s5p. Having not too much knowledge about batteries, i read a bunch of threads here in this forum but i can’t figure out if what I want to do will be compatible with the electronics. For the batteries themselves I’ll use Samsung 22F 18650, pretty much the cheapest good quality cells i could find here in Argentina so i’m kind of stuck with those (I could buy 25R’s but it would be MUCH more expensive USD$260 vs USD$500). I want to known what you think about those, will they work?. Would LiPo batteries work better?. in that case which ones? And for the BMS i’ve narrowed the choice to a few options but I don’t know which one is the most suitable for this build: http://bestechpower.com/37v10spcmbmspcbforli-ionli-polymerbatterypack/PCM-D223V1.html http://bestechpower.com/37v10spcmbmspcbforli-ionli-polymerbatterypack/PCB-D345.html http://bestechpower.com/37v10spcmbmspcbforli-ionli-polymerbatterypack/PCM-D336.html https://www.ebay.com/itm/36V-37V-42V-10S-60A-Lithium-ion-Li-ion-Li-Po-LiPo-Polymer-Battery-BMS-PCB-System-/221769582503
So what do you think? Again advice is very welcome hahahaha. Also I need to make sure that best tech can send their BMS to Argentina.
So that’s all. Sorry for my crappy English and i will be wainting for some replies. Thank you!!!
