Ahhh ok looks fine. You will not go very fast at all probably around 20kmh. If you haven’t bought the parts yet I would suggest the 245kv motor from HobbyKing as it will increase your speed to around 35km/h and it is also cheaper
ok i have changed plans 6347 192kv, 2 6s 5000mah lipo battery, Talon 120a 12s esc, 90mm wheels, 12t motor pulley/36t wheel pulley how fast and is the range on this board will be?
what is the range?
Depends on your riding style and environment
just the normal flat ground with an average a bout like 15mph
Should be very roughly 22km, using this super approximate calculation:
12S = 44.4v (using nominal cell voltages) 5000mAh = 5Ah 44.4 * 5 = 222KWh (kilowatt-hours) 222 / 10 = 22.2km
You could get a lot more, could get a lot less.
Thank you! ordering parts today😁
