I always wondered this when looking. I assume they are because you can select the color for two base plates and hangers, but they don’t let you choose the second base plate angle. WTH.
Anyone know for sure?
Also the description and info at the bottom is not filled out, website needs some love.
I’m pretty sure the RKP kit page is a pair. But the red 150mm RKP on sale for $79, no idea! The axle kits, no idea how many axles and spacers. The spacer kits, quantos quantos quantos! 10mm bearing is it 1 bearing, or 8 bearings – enough for 1 complete board? Dunno!
@deucesdown the kit i received came with 2 black 10mm and two 5mm spacers ×4, or for each wheel. They do not automatically include bearings, sf eyes or bushing washers
Edit: the sf 6900 bearings do not have a great shield. I got a set of contact-sealed 6900s on eBay for a descent price, and they are great so far (only 20 miles on them)
I don’t get the measures of the SR trucks. … If you get the 200mm and the 80mm axle, total end to end length would be 280 or 360?
Anyway, which length is recommended for esk8?
You don’t actually count the whole axle. If you use the 70mm axles that they come with your only adding 20mm to each side via the spacers so, 240mm. If you get @psychotiller’s mounts with the 80mm axles you could have, potentially, 260mm total hanger length.
Nope! It won’t work spacing wise unless you’re some kind of David Blaine.
I have a new design coming soon with a bigger flange/bigger mount plate that will clear the hanger and the outside of my mount. (I consulted Blaine) Guess what? They will also fit 176’s.
