sweet sweet sweet !! Is that fit Gummies well ?
Yep
Also it will work with 3:1 Gear box
10char
Just wanted to notify that we are working on 6"x2" alibaba style tire wheel hub
Kugy, I was thinking about how to install my new FatBoy precision hubs and come to the conclusion if you also offered some precision bearing spacers so I could get rid of the rubber o-rings Trampa use to make up for their sloppy fit that would be
What do you think?
Hereās what would be #1 on my wishlist for a design mod -
In researching 9ā tire options there seems to be only Trampas Primo hub or the fivestar hubs from MBS available.
Neither of which has a geared drive option from any vendor afaik.
Not sure what Trampa does to their hub, it does look like they have a second lip but MBS has a second lip shown in the product page
If this could be incorporated it would be a killer stroke, itās metal that would be be milled off anyway and it allows 8ā tires too.
Please consider it since I really want the off-road ability of a 9ā tire with a geared drive, I canāt be the only one
my next build
Which brand of 9" tires you guys would like, because if I understand Trampa/MBS tires are different sizes so you need to chooseā¦
The MBS T2 are appealing to me
Dimensions
Hereās the Trampa option
Dimensions
Result: same size
Nope, you are not. 8" doesnāt have enough clearance.
I would not be an immediate buyer, but the interest should be there. There are a few chewed up ādirectā gear drives out there.
Mine are already suffering, I use them on the beach my fault. But they also get hit by the odd rock, and Iād like to take them up a stoney road to a lake but the feet are already getting killed by just worn off road tarmac. I can put some rubber pads down but I think the solution is 9" for sure and the that will also solve my beach traction issues
The spurs are getting quite some abuse from sand ingress, if there were a way to seal the gap on the drives this would be perfect
v-rings are the solution, if your spurs are pom i would use a metal can between the āāgearshaftāā and the v-ring, cause plastic on plastic can melt.
Thanks Metal spur and Pom wheel gear from @3DServisas
Sand is getting in through the 1mm gap between the back plate and the Pom wheel gear
How do you manage to run in the beachā¦ without sinking in with the wheels and etc?
Good question!
Iām on 8" Superstars with Black Alpha 8 Inch Tyres - all purpose tires which were the beefiest tire option when buying Superstars
Temporarily I could maybe go to Trampa 8" mudpluggers for more grip
But yes, I can only start off in hard packed sand, and that sucks, in saying that there is plenty of hard packed sand and Iām spoiled for long, wide beaches. I get going and try to find the best sand, keeping spped up is imperative to not losing the plane on the sand.
These narrrow, small tires like to dig in and when they do like in this 52km get-off you can see the ālaunch patternā & ālanding zoneā here, it included what must have been a spectacular flip
I think you maybe want them to be almost out of air but just enough to keep tire on wheel it would provide more traction maybe?
Yep running them soft already, iām maybe 75kg
thats exactly where the v-ring would be;)
I just got message from @3DServisas that he started making design for 9" tire. Also I know there will be 1:5/4 gear drive with fully enclosed for hardcore off-road/beach stuff. Just what you would like
@Nordle itās inner gear drive. The whole outer case moves so no place to mount v-grove. The only thing I imagine is attach some kind of lip on top of baseplate to hide straight entry inside the gear.
