Have you decided on prices for hanger yet?
It was mentioned before
Group buy would be real nice, just saying
Will buy 2 if itās not more then 3 mouth away before itās rdy to ship :FatBoy Mini Drive Train + FatBoy 230 Hanger Group buy would be nice to save some money
How mutch is the clearence from the motor to the ground? It looks very little on the pictures?
Nice that looks alot better, was a bit worried from the cad pictures but that look great! The motor also look alot closer to the truck so clearence problem with the board/enclosure should be better if I can se right?
Yes, thatās why we are making longer hanger so there wouldnāt be any problems with 6374 motors
Hmm it looks like it wonāt fit on mount under the board for front truck, can you se any problem front mount it for the front truck?
Not really, also you will need to double check if it doesnāt fit under the deck in the front. Drive can have angle adjusted. Plus it will be pretty wide
Ok great, I canāt wait to get my hands on this
Finally our Dyno stand for our esk8 gear drives is finished. We will be able to test gear drives more accurately at variable speeds and loads and fine adjust noise to lowest levels.
This is how our first prototype looks under heavy load pressing on them. (Sound is distorted as the test was done in small room and recorded with iPhone)
Nice, how are you applying a load? Disk brake?
At the moment just down pressure, but itās enough to top up 60A batt amps on single esc
That must be putting a crazy amount of heat on wheel surface and bearings, looking forward to see what comes out of it
Sounds great!
Do the gears on the video have any lubrication?
Nope, this is old version, the first one. Itās for reference when the new one will be made
Will this drive be sticking with Flywheels over Kegals? At this point if the game Iām seeing Kegal Wheels a bit more reliable than Flywheelsā¦
Though , thereās no 110 Kegals in existence and Iām thinking that 110 is chosen because itās the minimum wheel for ground clearance?
