@onloop Your pragmatic and service-oriented attitude is commendable.
Could you shed some light on the kind of testing that is done on the VESC before they are issued to customers ?
I’m new to the scene but so far I’ve seen only VESC’s coming from either Australia or the US, I’d love to see them become available from a European source as well and I might even try to source them from a local supplier myself.
Any tips/recommendations ?
I know that its been stated that the gate driver pins 50-56 are supposed to be shorted, but the picture of @chaka 's VESC doesn’t appear to be, and is a lot neater.
If you take a look at the gerber files using KICad those pins are joined under the solder mask. It looks like a little clean up on the micro processor and a fresh tantalum capacitor might fix this unit. It is hard to say what cooked that cap, I see it was covered with a bit of foam. Could it have overheated?
Yes, it is still 2 weeks. That time is based on ordering PCB’s from Hackvana. I am going to order a few hundred for the next batch but that will probably go just as quick.
@chaka and @jacobbloy: I’m assembling a VESC but cannot find R15 in V4.10 anymore compared to V4.7.
Its a resistor 330kOhm at R15. Was it just omitted and Benjamin forgot to remove it from BOM V4.10?
They get powered on. They get firmware loaded. They generally work or they don’t.
I’m happy to do more testing though. I can do motors spin testing. What else do you want done? You probably looking at about some additional surcharge though.
however as mentioned in another post the black lead from PCB to Cap board is about 4 or 5 mm too short which brings the live rails alarmingly close to the servo pins. i’l be re doing that one before I do any testing.
oh… for what its worth I understand the need/want to get the power rails as close to the FETS without having to potentialy make the board larger with fat tracks. but leads connecting to the middle of a board is poor design in my books. (not pictured) on the otherside of the board the +ve lead runs right over the 5v pin on the CANBUS connector. its not shorting yet, but I bet a couple hundred ks on a skateboard will be different.
keeping in mind that this is essentially a BETA product, and its still in the teething stages. I wouldn’t expect any warranty to be offered and all work should be performed by a qualified technician.
Testing is fine but just plugging in every vesc and loading firmware and bootloader takes time, Iv written a script to cut the process in half but just plugging it in and pressing enter and parameters for ppm and enertion motors are preset. To do 120 vesc you can imagine can take a few hours, then to plug in a motor and pin test we are taking about longer because the time loading isn’t programming its plugging in and unplugging and plugging the next in.
Hi all! I also received the VESC 4.10 from Enertion. The overall quality looks good, but as @lowGuido I am a bit worried about the red and black leads at the center of the PCB.
One of the component has already cut through the insulation of the black wire and the copper is visible. As for the red wire it is indeed very close to the 5v pin.
For now I won’t plug the VESC as it is. I don’t like it, but I think I will try to re-solder these wires perpendiculary to the PCB. Also I will try to make a small PVC enclosure. Apparently a lot of VESC failures are due to shorts so I don’t want to take a lot of risks.
