Hey how do you set it to get smooth brakes? You raise it or you lower it?
Lower than default, Iām on 140kv motors though. I think each motor will behave different.
Thanks for the tip. I got pretty low KV overall on my motors, 75kv and 85kv hubs and a pair of 170kv so should have kinda similar effects !
Did you ever find a solution? I am running into the same issue. I get realtime data intermittently, it was working perfect until the last few updates.
Sorry, Iām really late to the party. Can I use Ackmaniac FW on Flipsky 4.20 dual? I like being able to use forward and reverse with brake, and this firmware seems to be the master of that functionality.
Should I just stick to the default or go with this instead? Oh yeah, running 10S BLDC of course.
Use Ackmaniac definitelly, there are no consā¦ ANd with the safety brake future and all other stuff, there is no debate
Thanks, now I just need to read 700 posts.
lol why? what do you need to know?
lol, just where to download, settings to lookout for etc. I got the jist of it, just donāt want to go to the hospital for being lazy and not reading up
Am I correct in that bluetooth modules donāt work with the 4.20?
ANd I was having troubles finding the firmwareā¦ is this the first time setting up vesc based esc for you?
Blutooth modules work fine with 4.2, itās just some phones and android versions donāt wanna work with the module
No, I set it up using the free vedder ESC. Not being cheap, just cautious. I got through my first setup and it works fine, just wanted to start playing with the +es
I can send you the ackmaniac firmware file If you give me your email.
I am currently using the Vedderās VESC Tool 0.95. I downloaded Ackmaniac ESC-Tool now as I have issues with the bluetooth connection using the original firmware. What is the process to change the VESC firmware to Ackmaniac custom one?
Boot Ackmaniacās ESC tool, connect to the vesc, go to the firmware tab, make sure correct version is selected and hit upload, done
Thanks! Will this override my current vesc settings?
Yes. You can export your current settings and import them after updating I think.
Is there a way to change between UART and PPM input from the Android monitoring app?
Would be great so I can switch between my 2 remotes on the fly! Maybe a feature request?
@Ackmaniac Any chance for an updated fw with bluetooth connection support? Just to be able to change settings with the Metr pro wihout plugging in that usb wire. I know vesctool 3.4 support this =)
