Used Evolve Gen 1 deck for sale with enclosure. There are cracks at three corners and possibly front, pictured below. Some blemishes and scrapes as pictured. Some of the mounting holes need to be reinforced but otherwise, great platform for a long range carbon fiber cruise esk8 missle.
Can fit 60 cells with BMS and dual esc comfortably possibly 70/72 (10S/12S) if you run without a BMS.
Heatsink not included.
Looking for $175 shipped (US 48 states). Sold as is.
There are cracks in three corners of the board. It looks like they are along where the seams are for top and bottom halves. Everything still lines up, just becomes aparent under load. Some strong, non-expanding epoxy resin should bond everything back together but I’ll leave it to someone more experienced.
No clue, it doesn’t look like a car incident as the outside finish is pretty good. I think it was primarily used in street configuration and ridden like it was supposed to have been. I got it second hand.
It looks like it separated on the seam so my thinking is that a strong, non-expanding, epoxy could be injected to secure everything back together. It only shows the cracks under load. Unloaded everything lines up perfectly.
The evolve deck is probably a bit big for what you are looking for, however, if you like a stiffer deck or your enclosure can’t flex, I’d recommend the truncated tesseract. Really nice board.
If you like a little more flex, the 34" landyachtz I have is awesome.
Cantellated Tesseract is similar with a kicktail but they made the nose of it a little fatter so it doesn’t quite have the same look as the Truncated.
I originally picked up the Truncated because it has the longest wheel base of any 33" deck I could find, compact and was on the stiffer side but didn’t feel dead like some other boards that feel like you’re riding a solid piece of wood.
