Which Anker flashlight is this?
Made a retaining plate (hummie deck) for these LIDL £1.50 light sets. Head and tail lights… hole for the push button. I don’t use lights a lot so it’s not like I’ll have to change batteries often. (Hopefully)
No, it’s these ones. Teeny and rubber outer.
Anker LC40
I thought you mounted drop through on your hummie deck?
Here’s the stl.
I’ve got a couple of decks!
Anyone tried to put leds inside a Hummie deck? I’m thinking is going this way, these lens that I bought are really small and together with some 3W 220lm Leds produce a nice beam
I may go WS2812b addressable led on the back on a cavity and them cover them with clear resin
The front will be the lens, only have to decide between 2 or 4 leds
What you guys think?
i want to make the whole surface glow do you know what kind of paint should i use to make it glow or any other cheap ways ?
RGB addressable light strips on the edge.
One idea is take a translucid plastic sheet, put leds at the edges facing inward and then sand the top, the whole surface should illuminate, there a few signs that are made that way
That is cool once you get it worked out please provide a BOM and design information.
Kevin
@Saturn_Corp I use those lights, they can take a beating…
Took it off my board because I’m moving it to my Mtb build
I recently got a pair of those lights but they are flood lights. I want lights that allows me to see the road far ahead, what should I use?
Spot lights… or get a hybrid (flood/spot)
Yeah,but any recommended ones here?
Haven’t personally used any except when I had my jeep
I like the sherlights. but it is too expensive.
Mine is great as well. Only issue is the mount that came with it split in two when I tightened it to the board. They’re sending me a new one which is pretty cool.
