So close to finishing this build.
Been working on it for couples months now whenever I have the time too.
You can see in my recent post I had a problem with my first enclosure being not tall enough. Eventually got another one that’s taller and everything fits.
Here’s the parts
Heatsink for dual focbox from @Rithblu, Bluetooth module and some free binds I think there called.
So the problem lol
Easily fixable I believe, just need to hit the hardware store and get some 12mm speed washer to space out the flywheel away from the mount as there are touching
Another question:
I’m use to building boards but not to much of embt. On the vesc tools I was thinking of putting these settings, I know it’ll work for a regular Esk8 but for a emtb will theses settings still be fine. What you guys think
Motor max: 60
Motor min: -60
Batt Max 50 (each focbox is 25a)
Batt Min -12 (each focbox is -6a)
Will this do ? Was thinking maybe lowering the Motor Max
Update:
Here are some videos
I’m the one in the red helmet
Purple helmet is my friend
Just waiting to receive my crossbars that @Rithblu already sent me so I can install them and post some dope ass photos for y’all before I mark topic as complete. Will be adding @Rithblu dualfocbox heatsink later on, right now I just want to ride and enjoy it for a bit before I add anything more.
Thank you to everyone and this forum. Without everyone here I couldn’t have made my 4 builds this year p.s today’s my birthday to 31 lol
But you guys are the awesome ones here
60a per esc that’s your max you can do though right. But once I can get a hold of those space washers I’ll be able to test the current settings I have. I’ll keep post updated
if its not to much of a bother for you switch the motor mounts to the opposite side of the clamps this will give you more room, so it won’t tough the gears, so no need for the spacers.
Freakin genius
Once I get home ima have to try that
Right on for the tip I think it just might work. I’ll keep you updated as well
Edit: tried doing what you said but my motor pulley to far on the side. My motor shaft not longer enough where the pulley and flywheel wheel will be lined up
I had one on an 8s setup not sure the voltage max was , I rebuild the board and upgraded the battery to 12s4p it was telling me it was 100% till this day so i put it on a desktop charger and it was really just a little above my cutoff.
@Rithblu Here’s what volt meter says
It was around 49v earlier before I finally fixed my problem
Only rode for about 15min but not to much since it’s dark af right now. This Friday I’ll have more time with the board and hopefully everything’s runs ok. Also didn’t apply locktight lol so have to go back and do that.
I wanna make sure everything is running ok before I confirm this topic as COMPLETE. Also here’s the measurement between each mount. Sorry didn’t have mm reader that long hopefully this helps.
Please check to make sure that your motor is close to center to the mounts as possible, because if your belt is to long the motor will be pulled back to far to use crossbar.
