This abomination is the current evolution of my first eskate, absolute trash but she still goes. It has been my campus board for several weeks in various versions; an average of 5mi/day on chunky bricks, uneven sidewalks, cracked roads. I’ve gotten nearly arrested already on it already but no injuries so far, fingers crossed
PHOTO GALLERY:
PARTS: ~$300
- stolen Blizart Huricane deck
- well used 90mm KooWheel Gen 2 dual hubs and front trucks w/ green Riptide bushings
- dual eBoards ESC w/ remote
- modded Meepo ESC enclosure
- 10s2p LitoKitta 30Q
- ABS cell holders with 16awg wire on pins
- steel bracket for cells
- used and discontinued AnnPower 40a BMS (bypassed)
- 2a charger
STATS:
- Speed: 22mph (charged) to 16mph (drained)
- Range: 18mi (eco) to 9mi(sport)
- Power: 680W
- Weight: 18lbs
All stats are from experimental real world data
I had to replace the heat sink on the ESC to match the plate shape in the ESC and added a foam strip to keep the dust out, it has SR30 connectors for the phase wires and extensions for the sensors
The steel battery bar holds all the cells in so they don’t fall out the bottom, it did that and it was not a good time, and protects them from impact since it transfers force to the deck
The deck came from my roommate’s Blizart Hurricane that he pulled apart and taped to a LY pintail and hasn’t used…such a waste, anyways I stole the deck so I could use the cruiser for a glowing push board and the Minority for the Pandora build. I made it a drop through because it was to tall for a push board and decided I liked it more at that height when I converted it
Since I don’t have an enclosure to attach an antispark loopkey to, I just used a XT90s for the BMS connector, and the BMS is hardwired into the battery because I don’t see myself replacing them and I needed the space
In previous versions the components sat in a cardboard box that was bolted to the rear trucks of the Minority or taped under the cruiser, this looks much better
There used to be a power meter so I could measure power and energy, the most energy I can draw from the battery is about 140Wh of the theoretical 216Wh because it gets enough voltage sag to go below the 30V cutoff. The most amps measured is 19.4A between the BMS and ESC when going full speed up a hill, I think the resistance of the motors is to high to pull any more
FUTURE UPGRADES:
- sheet steel enclosure
