Yes, even with the 100mm Boas they get warmer then the 60kv hubs I used. 110mm wheels with this drives would be too big for me. With the 110mm wheels Torqueboards Direct Drives are the best match I guess.
Kv is the same so then it comes down to stator size and battery. the more you can provide and the motor takes the more power output.
Well, my order is in for the “58kv” drive. It will be a good science experiment to see what I get so far I haven’t really seen anyone with the 58kv version. The ones that were supposed to have it seem to have 75kv specs.
the ones i mentioned before should have the around 60Kv version I believe.
Yup I don’t complain about speed
You got 48kph with 58kv drives?
What is the wheel size?
do not want to say that it is not true but are you sure the metr settings are correct? I see you use 10s and 50kmh is a bit too much also for 75Kv. I was getting that speed with 90mm wheels with a 110Kv motor. Maybe double check the poles count ecc…
Yes I can confirm with 10S, 20magnet poles in Metr. and 100mm wheels topspeed is around 40-45km/h ish.
At a small decline or with backwind 48km/h might be doable.
I tried them with 30A battery and 80A -80A for each motor and they got fun and torquey, but on hills 6355 geared setup still beats them.
ok that it’s indeed more in line with what I would. With my DD 75Kv at 10s I was around 42-43kmh with 90mm wheels. So with larger wheels totally possible. Thanks for the input.
Boa 100mm 10c
I run 11s on 100mm boa
ok then perfect
i’m thinking of using this DD Drive on a pantheon trip. any ideas for enclosure and battery pack that will match the setup?
Will be using the double kingpin trucks and Boas.
Thanks!
thanks! this looks perfect
People interested in elofty 6x2" pneumatic wheel, please vote here:
What kinda prices would we be looking at?
It’s right here.
at the time that i did not know the 3.0mm and 3.5mm. so make me confused , for now that i knew it. so sorry about that.so i jsut send photo to make you know it ,
