You should find the information on where to place it in this thread.
i need to find another motor because if i buy motor on hk i’ll have to pay for shipping 20$ and it’s too much
Did you select the EU warehouse and not the international?
If it helps you can get 10% off with “hobbyking10”
motor don’t ship from eu/uk
yea, i’ve used it
They went out of stock. When I checked two days ago was possible. I will look for other motors on HK
Keda 190kv 10s maybe? It’s definitely not as nice as the one you wanted or the 6354 model of the turnigy.
then i think, that I have to keep looking
https://hobbyking.com/en_us/turnigy-aerodrive-sk3-6374-192kv-brushless-outrunner-motor.html is a good motor. Doesn’t have sensor and is not sealed but I won’t ride with rain anyway
Here we go from Flipsky https://www.banggood.com/it/HGLRC-Flipsky-S-6374-190KV-3250W-Brushless-Sensored-Motor-Shaft-8mm-for-Electric-Skateboard-Rc-Model-p-1318795.html?rmmds=search&cur_warehouse=CN
lack of sensor isn’t a problem, i’ll always push board at start, and it looks intresting, i’ll buy it
Check the flIpsky. It’s the classical motor Torque Board and other use. Is good and has everything,
I linked in the previous answer. Check it https://www.electric-skateboard.builders/t/electric-longboard-beginner/65465/110?u=rey8801
You can also buy it from the Flipsky website if you buy the motor and the VESC then you have free shipping. Plus there is a 20% coupon code. If you need it I would have a look
I’ve already bought vesc, and shipping is 20$. I’ll buy motor from banggood
Definitely, only if you didn’t but the vesc was worth it to do it. That motor is really strong.
ok, i’ve already bought things from ebay (motor mount, pulley kit) and aliexpress (kapton tape, vesc, wheels with bearings, remote, series connector and battery indicator) now only thing left to do is hk (5.5 bullet connector, xt60 connectors, two batteries, heat shrink and awg12 wire) and banggood (motor) all is good?
you also need xt90 antispark if you want to make the antispark loopkey. The rest looks fine.
I’m sure xt90 are cheaper at bangood
