No problem. Take your time and read when you connect batteries, vesc ecc…otherwise is easy to blow stuff. Good luck!
I was just about to order, but i think i forgot about anti spark switch/ power switch, but i can’t find any cheap one, could you help me?
You can use an xt60
Fair price and super nice, I am using it since day 1 @Martinsp http://electricskateboard.repair/index.php?id_product=36&controller=product. Otherwise you can make an antispark loop, it is cheaper but kinda annoying plug and unplug it everytime.
25€ is kinda too expensive, i world prefer antispark loop, if i build one/buy then how am i supposed to connect it? My series connector is wireless
You should find the information on where to place it in this thread.
i need to find another motor because if i buy motor on hk i’ll have to pay for shipping 20$ and it’s too much
Did you select the EU warehouse and not the international?
If it helps you can get 10% off with “hobbyking10”
motor don’t ship from eu/uk
yea, i’ve used it
They went out of stock. When I checked two days ago was possible. I will look for other motors on HK
Keda 190kv 10s maybe? It’s definitely not as nice as the one you wanted or the 6354 model of the turnigy.
then i think, that I have to keep looking
https://hobbyking.com/en_us/turnigy-aerodrive-sk3-6374-192kv-brushless-outrunner-motor.html is a good motor. Doesn’t have sensor and is not sealed but I won’t ride with rain anyway
Here we go from Flipsky https://www.banggood.com/it/HGLRC-Flipsky-S-6374-190KV-3250W-Brushless-Sensored-Motor-Shaft-8mm-for-Electric-Skateboard-Rc-Model-p-1318795.html?rmmds=search&cur_warehouse=CN
lack of sensor isn’t a problem, i’ll always push board at start, and it looks intresting, i’ll buy it
Check the flIpsky. It’s the classical motor Torque Board and other use. Is good and has everything,
I linked in the previous answer. Check it https://www.electric-skateboard.builders/t/electric-longboard-beginner/65465/110?u=rey8801
You can also buy it from the Flipsky website if you buy the motor and the VESC then you have free shipping. Plus there is a 20% coupon code. If you need it I would have a look
