With a 12s3p or 12s4p there could be a max of 80Amps flowing through the VESC’s. Have you had an issues with your VESC’s?
My skating experience has been limited to carving because of flat florida.
Split ppm?
Why ppm over canbus if both my motors are identical?
Because canbus fries your vesc’s if they’re not powered up simultaneously?
Oh. I am planning on using an adapter that will reduce both VESC’s to a single XT90 that will plug straight into my battery. What do you think of that?
oh yeah, i forgot. Carry on.
Yeah that’ll work fine.
I run 12S on FOC on all my builds, it’s perfect!
With a 12s3p or 12s4p there could be a max of 80Amps flowing through the VESC’s. Have you had an issues with your VESC’s with that amount of current?
What? On your website it states: 30A Continuous Amp Output and 80A Peak Amp Output.
No problem. If I was going to use your 63mm reverse mounts, what pulley length would I need? 320mm? Also could you estimate the performance difference of a dual 6374 using your 12s4p versus using your 12s3p?
