Hi Jens, could you tell us the weights of your new ISO-06B chain drive and the weight of this new DirectDrive? (metal parts are different compared to you first version, that I have and that is really great!!).
Dude!
Awesome, put me down for one bro!
Yes Dudeā¦ in the end the parts are readyā¦longtherm expierences missingā¦ means dont know how well bearings will handle sideloads ā¦ but be aware that they even more expensive then my actually Driveā¦ around 125ā¬ more
@DavidC I really have to put all stuff on a scale, cant say actuallyā¦ Lightest Drive actually is for sure the actually Mini Driveā¦ Remind me if i forget to give you more feedback about wheight Bro
Bearings are cheap JensBro
count me in!
Great comment, piss my pants
Have your Encoder and Enclosure Stuff by anadosizingā¦ could ship by end of next week hopefully
We can sort it out via PM
Do you or duffman make the helical gears? Or is there a place i do not know, who sells them at an affordable price?
dunno man, motor bearingsā¦pulling apart them big motors sucks. These motors were supposed to push big props (SK3 anyway), would be interesting to know what the difference is in forces applied compared to the ESK8 application with helical gears.
Good point regarding the sideloadā¦and the price. At this point, Iāll take the noise for granted. But dangit, quiet direct drive will be a heaven for most.
Customer upcoming.
My scorpion airplane motors pull apart without too much hassle. I have already put helicopter motor shafts in them, so I have experience pulling them apart. I have a drill press I use to push in/out the press fitā¦
Wait and see, can always go back to spursā¦
If I donāt get them I will regretā¦
Where can i get them?
I guess everyone who is making geardrives for esk8 is looking for helical gears but unfortunately they are hard to source. Either they are very expensive or only available in large quantitiesā¦
So I did some R&D and manageds to machine my own helical gears. Specially tuned to match the same axle distance as the gears used in Jensoās DD.
These are a 1:1 drop in replacement. Put them in and ride smooth and silent.
Holy fuck guys - when can we order!!!
Holy crap. My mini direct drive hasnāt even been delivered yet but time for an UPGRADE!!!
Next level, what helix angle are these gears? If the ratio between radial and axial force is lower than a given number, there are no problems or effect in life cycle, I donāt remember the exactly number, but in the SKF design manual all procedure is explained to calculate to account for side loads with spherical bearings
Please make a video of them side by side when possible!!!
They have 22.73 degrees helix angle. This is the skew you need to get exactly one tooth twist on the given width of the gears. So there is always one full tooth engaged at any given time.
Thatās good, when you see Jed boards gear, they are to thin and have way less than a full tooth engaged, maybe it will work ok, but for noise reduction at least one tooth is good practice
+1
Iāve generated some hype with that pic. Do I earn a prize?
Nope. Youāre not the one who made itā¦
