So wait I’m not sure if i understand right, you allready made that expereince, or is it theory ?
would your 6374 Motor alo have such strong regen-brake ? or is it because of the Leo ?
PS.: your package arrived, juuuuh “sadly” I’m going on vacation tomorrow, so my direct-drive project has to wait a bit longer, still,… thanks allready… looks like fun
Not theory… real world (-;
Sounds logic too IMO, once the wheel stopped the Vesc says OKAY start spinning backward is okay
This can happens on loose terrain by full brake …
Its nothing i´m worried about… just wanna share it… for what i should need RESERVE on MTB really ?
You got Bindings, do a 180…
Nice that you got the Parts Dude … Let me know if i can help ya anytime
It is a little disappointing hearing about reverse actually. All the time Benjamin has spent “banging” on the vesc tool. Well in ackmaniacs bldc firmware you can program reverse like hobbywing where you have to double tap the brake but in addition you can program the speed for direction change so you cannot have one wheel spinning in reverse at 15mph (as easily.)
So I wonder if anything has changed in duty cycle from the previous version where there was no neutral. If you have a chance can you test this mode.
Oh Ok Dude i have to say i just played around…
it was not my goal to archive this reverse stuff in total, just for fun…
what i wanna say, thats maybe easily to archive your goals if you know what ya do
i never know
How big of a jump/difference in performance is it going from 6374 to 8072? Mostly wondering about the difference on hills (up and down/braking), but also in acceleration and anything else you’ve observed.
I dont think thats a big difference in the end…
You get a cooler running setups on high amps… positive if you live in hot/hilly areas and if you are a heavy rider…
Mainly i done for science, but in the end i like it alot… badass
MAchined another lid for my Vesc enclosure,
Mr Maa a buddy from mine working on a Logo and this was an first attempt :
The clue is really to working with shieldet wires… first tests with unshieldet ones gives me a lot of noise and no good detection… with shield i´m getting a super clear signal :
I got some similar looking… but have two crimp always twice, first the real connection part and second the insulation part… its annoying… maybe i should get myself some nice glasses with lights… could it make better…
@trampa
The Encoder is jumpered on 5V… what do you mean by running them on 3.3v ? How to switch the switch on the Vesc , what for a tool you use? A thoothpick?
You can set the PCB to take 3.3V. Read the AMS PCB manual! Some smd soldering is required.
Set the VESC to supply 3.3V on the sensor port. This will reduce the noise and worked better when testing the AMS5047P.
