Also it would be maybe nice as an upgrade to have some “Leo Adapters” which where able to carry a Brace (-;
BTW i have to redesign the Adapters anyway for use with the Stainless drive parts because of clearence issues for the two nuts in the motor area…
To get full advantage of VESC 6 I’d add hall sensors to those leos, I think burnouts from stand still would not be an issue then It’s pretty simple, you just may need to mill small slots between stator ribs and then glue halls with soldered cables
Just my two cents, as always Jenso, You keep pushing boundaries further and further!
Why would sensors keep this thing from burnouts?
If the wheel slips the hall sensor does not know that.
Sensors only help cogging issues and to get the motor going - they are not used for traction control AFAIK
I do not know the leos from inside, but with some motors you could just glue them between the starot teeth. Sure then they are perpendicular tu the rotormagnets but that does not seem to matter.
At least in my sk3 that worked if there is enough space above the windings
That’s why I put “may” in that sentence I had to in my emax GT5345, gaps were to narrow but assuming Leo’s are 80mm outrunners it indeed may be possible to simply glue sensors in stator gaps
Maybe I’m missing the point, I think Jenso wants to see what brakes first…E-Toxx DD V’s Vesc6 V’s 80mm Leo…
this is destruction testing!
Just hope Jenso, doesn’t blow up batteries trying, that would be a win for all three!!! & biggest fireworks yet!
Thanks Bro
You are absolutely right… i wished i have done this before glueing the spurpulleys to the shaft…
so we will go with a NON sensored test first
but already talked about @BigBoyToys about some nice APS 80mm sensored outrunners
Oh i would like a big Lipo firework alot… never ever fired a Lipo … would be only nice to get out of Bindings+Heelstraps first
In the end Dude its what i´m looking for !
The point where you really feel that the machine will perform your skillz out…
Tame the DEMON
Alien power is happy to make these motors as per our specifications. I placed my order this morning for 4 sensored 8082 outrunners with 33mm length/12mm diameter shafts with 3mm keyways. They will wind to your KV specs as well. He quoted a me 3-4 week lead time .
