I’m planing on upgrading to dual drive and I’m researching how things should be connected. As I understand, there are at least two options:
Set up the VESCs as master and slave, and use the CANBUS port to connect them.
Split the signal from the remote receiver (Y split). Have the same config for both VESCs then.
CANBUS pros:
Traction control. If one of the wheels looses traction, the interconnected VESCs can figure it out and adjust the spin of the other wheel.
Realtime data can be read from both VESCs over single USB.
CANBUS cons:
less reliable
If the master VESC dies, the slave VESC has no input signal and can’t work. Problem if going downhill since brakes won’t work on any of the two motors.
Can fry a VESC if not connected correctly. I have seen a few mentions on the forum that you should never connect the CANBUS when only one of the two VESCs is power up since it will fry the VESC.
Does this sound correct? Are there other pros/cons?
Also, what exactly is the issue with having only one of the CANBUS connected VESCs powered up? Does the problem also apply when one of the VESCs dies? I mean, does it mean that if one of the VESCs gets fried, the CANBUS will take the other VESC down with it?
And last question: If the two VESCs are not the same, does that change anything? For example, I have the ESCape. I think I’ll just get another one, but I’m also considering the FlipSky 6.6. With the Y split, could it happen that the two different VESCs will interpret the input signal slightly differently and one will spin the wheel faster than the other one? Would that be any better with CANBUS?
As far as I know the Flipsky 6.6 don’t have any issues with disconnecting CAN wile operating.
With all the new dual vescs you also don’t get any problems as the CAN bus is hard wired via pcb.
I have canbus with dual 192kv 10s. A beast!
Its super! No problem with canbus. I connected splitter but one motor was more delayed… ( maybe i did something wrong xD) also when i go offroad, trsction controle is super Nice in the dunes!
CAN bus all the way. Split ppm exibits annoying behavior on the street in my opinion.
also if you do things in the right order you don’t have to worry about it.
connect CAN bus leads,
connect both VESCs to power supply while it is still off
power on
configure
enjoy
@blasto correct me if i’m wrong but didn’t Enertion already fix the “only one CANBUS device powered on so let’s blow the other CAN controller” issue in the focboxes? It seems like i would have accidentally blown more focboxes by now if they hadn’t.
Indd, CAN all the way.
Last time I had this discussion, we concluded that there can be ground loops present in the splitt ppm scenario. Which isnt good.
I’m not sure how you fry a vesc thru CAN if you’re only using the data lines between them
I just blew a FOCBox using canbus and it was a FOCBox purchased less than 3 months ago. You have to consider the situation in which the canbus cable comes loose while riding.
Also, I have never experienced a single issue with split ppm and I have noticed no difference with or without traction control. That’s my 2 cents, but really if you go with canbus just put a dot of hot glue on each connection and don’t screw with it unless all power is disconnected.
I bet you a year from now someone else will be googling and searching for similar questions and answers and will stumble upon this thread and find some info that will help them solve their problem.
I see this all the time on other forums where someone gets upset that someone else made a post asking a question that’s similar to a thread that has been made in the past but yet that ends up being the thread with the most helpful answer for someone in the future. And I roll my eyes.
There’s a difference between invasive spam posting and people actually just trying to learn and ask questions.
By saying you want to close the thread because your upset that there is another similar thread make sure me think you should just leave the forum. No offense.
