Just sent for anodizatio should be back by the end of week
Just when things couldnât get any sexier
Paid!
ORDER #1042
Wondering, is there any chance of a picture or two with it placed on a board, maybe top tail and underneath tail mounting options for perspective, i say this as your single vesc box looks way smaller fitted than i assumed it would be from the pictures of it i had seen with the white background only. .
Sorry, but there are no board at the moment where the cases are If you want to imagine the size I suggest just to make a paper box of its size
Or you could wait for people who will receive this week to add some pictures
No worries, il use my imagination til people start receiving them and showing off your wares, and as you say that shouldnât be long, and iâm in no rush, thanks for the reply.
Awesome work man. How close are these to being waterproof when using the rubber grommets?
âWaterproofâ means you can run it underwater in a pool. âWater resistantâ is probably what youâre wanting?
Closer to waterproof tbh. Say IP65 or better
I would not even say they are waterproof but more water/splashes resistant
Can I swap my order to one with fins please? Order: 1021
Check your email
paid! thanks.
Do the box, have space, for the + and - connection between the two focboxes ? So we only need to run one main + and - wire out of the box ?? Thinking of using this box, on a AT board, like TrampaâŚ
why do people keep looking for waterPROOF? Seals can crack and wear down especially with the vibration these things go through.
Maybe you can add a silicone seal and also a hydrophobic spray to seal everything, but like I mentioned, vibration will eventually cause a problem somewhere on/in your board
There are two pathways for two power supplies cables, I donât know if there will be enough space for putting cable inside as we do not have two focbox to try it out. But I think with some tinkering its possible, worst case scenario you can just route Y style cable to both of them and have an only single connector.
Errrm maybe a silly questionâŚI preordered 3 of these 3 x âŹ5 discount as thought this is how it worked?
but have no way to enter all codes in my checkoutâŚonly one can be used
Any suggestions?
I sent you a message
Looking forward to se some pictures, with focboxâs installed. How are you planning to use the box, if itâs not on a AT board.
Iâm golden, thank you
Yes, there is no need just for AT board There will be also finless version available which will be lower by fin height
