NICE!!
Very nice!
It could make a good tiny compact and nice looking sandwich with it, motor wires itch on there way ! Nice !! (IMO ) FKN LEGEND credit inspiration (on his last vid)
Didn’t quite understood
it doesn’t really mind it’s a detail, just to say that this layout was inspired by @Nowind
For those of you using the full case, are you using Bluetooth modules and if so where are you putting them?
I use the bluetooth module and the full case. Il could not manage to put the module inside. So, il. is attached to the bottom of the box. I got the receiver PCB out of its plastic case and it’s attached at the opposite side.
Thank you @DavidC, that’s about what I was expecting I’d have to do. Did you do anything to the module to protect from moisture?
Yes, heatshrink tube closed with hotglue.
Awesome thanks again for responding.
Use silicone conformal coating or drydrone to protect from moisture
I just got one for my single motor board and the construction quality is fantastic!! I am going to trace the heat sync & cut a hole so I can drop it through the board and set it with epoxy & added silicone seal. That way I can still have my fully waterproofed enclosure and air cooling at the same time
I’ll take some pics and post them here as soon as I get it done.
Any idea when the cases will be back in stock and how long does it take to ship to the west coast of the U.S.?
Will be available in a week Should take like 5-8 work days
Awesome!!! Will you have any red ones?
The cases are back in stock, the red one will be available in a week time.
Do you think you’ll end up making one for the unity?
Maybe if someone will provide one
