Unless you’re going to seal all the screw heads and anything else exposed/not sealed off you have a chance of getting water in the case.
Okay, thanks!
I have actualy not any clue in how to waterproof the screws ? Maybe some rubber washers with some oil on them ( since water don’t mix with oil) I need to find a solution anyway since without airflow the fins are basically useless
I ride with a single one stuck onto the bottom of the deck, just a piece of tape over the USB port, all the bolts have rusted, not a single drop has gotten in, make sure the grommets are on properly
You can always replace with stainless hardware A dab of Vaseline under the bolt head will waterproof it
On another note @scepterr have you needed any locktite to keep the screws in place ? I was a bit worried about the vibrations and since you are already riding it u could maybe tell
I never have, though I have a pad under the enclosure to absorb vibration I’ve got about a half dozen riding around NYC with no loctite I’ve got one client who rides daily by the ocean, on the boardwalk, the only damage and something I didn’t expect were his ppm wires getting disintegrated by the salt, upgraded to 18awg and heavy sleeve
I’m in the final stages of my build. I have to shorten all my wires. Then my plan is to use high temp rtv to seal the case. Probably don’t need high temp but it’s what I have right now. I’ll loctite the screws as well for the final closing.
For sealing the bolts i would suggest butyl tape or silicone caulk (sika flex) thats what we use for deck hardware on boats.
Yeah high temp silicone gaps
Good to know. Even after it’s all sealed up I’m only gonna call it water resistant. For sure a work in progress
Looks like it fit inside really nicely
Just a reminder for everyone who needs a good case with improved thermals for FocBox’es
Single, Double cases
Can confirm these things not only help aesthetically and for mountability, but they keep the FOCBOX running much cooler so it performs better
I think there is even posibility to “overclock” (run at bit higher current than allowed, as heat is dissipated much quicker and it runs cooler)
Already testing that. I think my 8ga wires are getting hot as well though. I saw some discoloration near my loop key on my kydex enclosure. Going to open the box to further inspect. I didn’t see any melting, discoloration, or warping on the wire or key itself.
I’ve bumped my battery amps to 65, however I haven’t surpassed 55A on my setup. It’s dual 6374, but I think some larger motors would easily pull more battery amps.
What connections did you have to solder? Are you using canbus?
