I got one of these enclosures and I’m wondering if anyone has fit a “standard” Vedder VESC in the space at the front/back? I got the enclosure with no extra display/switches on it.
When buying it I thought I should be able to, but now I have it in my hands/in the flesh I’m not so sure.
You’re going to want additional cooling for those vescs. Ime my single 4.xx vesc started to overheat while in that enclosure. It was set for 25a battery amps, which isn’t much 🤷
I’m running two Flipsky 4.12 Vescs at 20A battery max each (that’s all my battery will BMS will handle) and haven’t had any VESC overheating issues. There are twice as many FETs to carry the load with the dual setup though.
Put a heat gun to that enclosure and you can manipulate the plastic alot. I cut out most of the internal walls, remoulded the shape of it by simply putting heat gun and shaping it with a block of wood cut to a similar size to what I needed.
I have a 10s5p battery shifted all the way to the front and the rear part widened to fit the larger style generic ESC. It worked out fine for what I need. I needed space for 2 esc for 4wd.
