Yeeep! Also they might make some 107s, but im not sure i only heard them talking about it once.
Do the airles AT tires work with the evolve hubs
Yeah works fine I made a post about it on reddit but a mod on reddit removed it for some reason.
@Lumaci do you have any Chinese belt drive boards with the same diyeboard type esc that it works with?
Nope, but they use the same esc.
Remote will work on diyeboard kits, meepo boards older versions of wowgo riptide and such but the telemetry wont work since it needs the teamgee esc for it with the extra urt port
does this mean the new meepo controller would work with the v2.1 esc
It should, but you wont see any benefit other then cosmetics.
The throttlecurve and more is programmed into the esc
does the battery indicator on the remote work with the esc not from teemgee?
Yeah the battery for the remote and board works, but its not that exact
It is much more comfortable though and will hold me over utill the VESC comes out in October, have voltage monitors on top of my trucks so could care less on that accuracy
It also has cruicecontrol thats a nice feature, but it feels kinda cheap cuz its so light imo.
easy to add weight, hard to remove weight
No space inside the remote for weight and you fuck it up if you open it, already tried theres some adhesive holding on a rubber pad that has a screw under it.
the new one?
how do you activate the cruze control on the teemgee remote?
double click the wheel at speeds above 12km/h and it will say CRU on the display,
@diyeboard - Jason, would you recommend threadlocker on these bolts (both on the truck and on the wheel), or do they already have it?
FYI Jason replied privately : βDonβt make any change, as thereβs already threadlocker locked well, also we put the thread glue when assemble then, so better do nothing.β
Never can go wrong with thread lock on high vibration points
