After reading about px90 it seems px60 should be added in proportion to achieve a 74 shore rating for proper rebound for longboards
Mixing px60 and px90 is a good idea!
Oh yes, thatās great!
Xencast works with 2-part silicone, in my quick test with aged silicone. That is you can made detailed mould and donāt worry about getting small details stuck in there. Mould with seprataed walls althou two part silicone can be flexed to rid the mould of negative surface part
Adding reinforcing fibers would be nice as well to support small details. Maybe even metal powder as āhardā abrasive resistant element
This is my casting project so far:
Goal is a AT PU sleeve for a landwheel drive based on my front MBS AT wheels. I already did one first try āPi mal Daumen / pi times thumb ā which came out unusable but I learned a lot of it about silicone and PU handling. One big thing was centering. This time I used a M8 screw used for first centering and holding the Original wheel and then for the cast holding and centering the sleeve. Now its time to wait for the results but Iām pretty optimistic. I canāt wait to cast the second one so I can test it on the board edit: And yes, I just casted the new PU on top of the original one, before I did that I used the dremel to cut it in different shapes so the new PU would get really good contact. In the first try it turned out to bond impressively.
edit: Here is my first try:
mh would this method work with casting real rubber? And does anyone know a vendor for rubber?
not perfect yet but almost I still have centering issues but Iāll solve it next time. This time I wanted two sleeves to try out the pu so far its looking good
are those the sleeves you made? they look like the real thing. nice work
Just in case: The casted wheels are the one next to the floor Iāll take better pictures soon
Still thatās a killer result. How did you center the mold and the original wheel? And I havenāt ridden yet your olā hubs itās raining all day!
I used m8 screws and a printed hub for the sleeves
The new version (and hopefully the last):
This time the centre screws are mounted rock solid
nice work. How durable is the Resin you use?
thatās a good question, so far it looks good but I didnāt drive much with them. the two I already casted are not well centred and thus vibrate a lot. funny thing: when I drive rough roads the new sleeves are way better but on good ones it vibrates like hell (my glasses shake )
lol ok. can you link your resin you used?
I used PMC 780 dry by Smooth On.
Really nice you! Now I am curious to see how long the PU will last. Good job!
The first acceptable version:
I feel confident about them and have put the red loctite on the screws
It looks sick! Super nice.
Looking great!!! Any wobble on the rotation? Looking forward to seeing this one age well !
No major wobble on rotation, no. When spinning the motors its almost as silent as with the original PU. Iāll try them on the road later today The left wheel (right one on picture) I cut away a little bit too much making it a bit irregular but it should work anyhow
