Discussing esk8 deck: "Doobie" 39" Deck with Kicktail & milled out area for electronics
This is where we have a focused discussion about the 39" Kick tail Deck with a milled out section for batteries that supports up to a TBC battery configuration , made by @drangboards
  • Flat mounting area for battery and electronics - Aiming for 150x534x12.4mm (need to calculate what this area can actually fit)
  • 10" Wide
  • 39" Long
  • 8" Tail
  • 26" Wheelbase
  • Price - TBD but it will also be available for people in Europe
image image image image image image image image
Enclosures can be made by Psyschotiller and Bigben I presume.
I am just here to make @drangboards life easier and make sure we are on track and don’t derail and continue with progress
WOULD YOU BUY ONE?
  • Yes
  • No
0 voters
I’m into it, especially if we can get a sleek enclosure from @psychotiller made for it. How many layers you shooting for @drangboards?
With a .5" channel being routed, I’d say this needs to be 11 or 12 16ths of an inch thick. If we used carbon top and bottom we might even be able to go down to 10, but we’re talking about 12 here if it’s wood only.
Great. Im good with wood.
Whats that in metric?
Let’s see if this works
Length Conversion
Can’t wait for the freedom measurement discussion
I’ll make sure to simply convert the file over to MM, so all you can stay calm and get stoked.
All wood since the cost increase for carbon fiber is drastic?
Woods also better at absorbing vibrations
Yes wood only.
This deck with a 26" wheel base will be stiff enough with wood only. Composite after that would make the board overly stiff, and too heavy.
It can be done on a deck with a bottom route that isn’t as deep as this one is.
If anyone sees this, and wants to talk about a deck outside of this deck specifically, then pop on over to the Drang thread, and post there. www.electric-skateboard.builders/t/drang-boards-deck-building-services-design-cnc-etc
Poll added to original post
I do wanna know if tiller plans to make an enclosure for it tho.
Is the kicktail upturned, or level with the rest of the deck?
And i accidentally made it private lol
Lol that’s what she said :crazy_face:
@skunk really does make it to easy :joy:
Yep… she tells me often of my skills with wood. Bragging to her friends. Now they all give me odd looks when they come by.
What is the max size wheels I can use with this on caliber trucks?
