You are good I am making plenty extras
Hows it going with these?
Still waiting for pcb, have some issue earlier. Will post update asap.
Just given the go ahead on the pcb v0.9, we can start when it arrives.
Sam
A newer revision? Has much changed?
Nothing, just added test points for faster mass production testing.
Hmm should be done before that but have to consider shipping time. Thatās quite a variable, will try to push for completion asap.
No rush from me still ordering parts for a 2nd build
I have a battery waiting for this only. Would be good to get it asap! Take my money
same here.
Just waiting for pcb now, order was placed.
The kit doesnāt come with temp sensors does it? @JTAG is there a sensor that you would recommend using? I figured if itās there I might as well use it!
Would like to join in
Just sign up, making quite a bit extras
I guess signing up is sufficient for the moment? filled in the form for 2 units.
Yeah, will start the assembly soon.
check the main thread, I asked the same, i think its a normal 100k ntc thermistor, but better take a look. Works like a charm
(look for NTC, it will show up)
Hope thereās space left, just signed up!
