Mine arrived in the US in I think 5-7 days. Shipping was very fast and zero issues with customs.
So I was planning on connecting both VESC’s (dual ESCape’s) to the DieBieBMS. I was going to use a canbus cable with just the two wires for one, and the other cable with all four wires connected. Is that it, or do we also need to connect the VESC’s to each other directly as well? A bit confused about this aspect, lol.
Tracking for mine was created around the 8th of August. It arrived in Germany on the 10th. since then I’ve had no updates for tracking or letter in the mail. Its just sat on “held by customs.”
I would not connect this directly to charge your battery, it is a voltage source (fixed votlage) but you’ll need a CCCV, Constant Current Constant Voltage device, hence Lithium charger.
keeps the current fixed and let the voltage increase to 4.2v/cell (50,4v in your case)
when at max voltage, keep voltage stable, reduce current until ~0.
this BMS will only monitor and balance your setup, it is not a charge regulator
in case of 12s you would not be able to fully charge with this charger
look for (e.g. at aliexpress) for a “12s lipo charger”
The Meanwell ELG I use is a CCCV, but I don’t believe the LRS is. Ordinarily this would cause problems for a BMS…
BUT the DieBieMS is no ordinary BMS, it does switch off charging. Watch it while it balances; will do bulk charge at 2a, drop current to 0 while it bleeds the high cells, then repeat. I’m not sure it needs a CCCV charger. I’ve certainly never seen a charge amperage below 2a (or thereabouts); it’s either 2a or 0a (see pic below).
I like having the Watt meter in there to keep an eye on things.
Voltage needs to be set a few volts higher than the fully charged voltage, this is something specific to the DieBieMS. Somewhere in one of these threads JTAG mentions why. Your Meanwell will probably do more than 53v (mine does), so I’m pretty sure you’ll be fine at 12s too.
The DieBieMS is indeed a clever BMS, but remember it still won’t regulate the charge voltage/current for you. The CV part of CCCV has to be 0.7 volts (series diode drop) higher than the rated pack voltage. but at the other hand, keeping your cells just below 4.2 (for 10s ==> (42v - 0,7v) / 10 = 4,13v/cell) is actually relaxing your cells and increasing the lifespan
Note that the parameters for balance charging have to be adjusted.
Normally during balance, the pack is overcharged by e.g. 0,2v/cell, and after that the high cells are discharged (into heat), not sure how DieBieMS does this since it has no control over the charge voltage.
over a regular BMS, this is what DieBieMS add’s
High quality parts
Highly configurable (cell count and thresholds)
Open Source
Connectivity (CAN, USB, wireless (optional) )
Integrated soft switch & OLED indicator
That meanwell ELG supply looks nice, (expensive but high quality), I just use an Aliexpress and never charge unattended (unattended charging of lithium is a bad idea anyway )
36 days since it was posted and 29 days being held by customs and finally it has been updated and released.
I want to know why they thought it was needed to hold a package in customs for 29 days without giving any reason. Is that normal for Germany? Do they think I’m smuggling in 3g of drugs between the PCB layers?
Now I need to get a charger sorted for it. Does anyone have any recommendations for a good setup for people in EU?
Thanks for the notes on charger, I saw in the instructions that a CC charger was required. I did not know that CC = CCCV. I have several 12s and 10s lion chargers.
So, Now that I have it all wired up and I want to go and change settings, must I use a 12s pack/power source? The OLED reads bye and flashes a battery crossed out symbol, presumably because the BMSs was programmed last during testing to 12s 3a.
