Well looks like either ur bootloader was overwritten / flashing firmware failed because of lost connection or etc lost byte and etc.
Definitely something went wrong. However it was not during the firmware upgrade which was successful for both vesc. After the firmware upgrade I proceeded with the motor and connection wizards and everything was working perfectly.
Oh sorry as I skimemd i thought u flashed and it bricked
Is doing the read settings flashing firmware ? You got me confused af.
I have issue with metr as well. mine is vesc6, everything was working until i used one of the modes in metr. Both vesc was acting weirdly. I just re-flash my vescs and everything is working again.
I did emailed @rpasichnyk regarding this issue, he suggested not to use the modes features until he find the solution. and this was somewhere around 3 weeks ago.
Mine after flashing the modes was stuttering when starting
yeahā¦i had those as well
actually redoing the settings directly through the metr fixes the issue, for some reason it seems like adding the metr after settings are added manually thru focbox directly causes the module to load itās own incorrect settings, but changing the settings through the module itself seems to working great so farā¦
i know it may not make much sense, but itās worked fine for me so far, and iāve ridden 25~ milesā¦
It doesnāt, tried that countless times.
The metr shows connected, but it doesnāt allow you to make changes to the master when itās in āblueā light mode only.
Same thing here.
I am willing to help with this bricking issue, please get logs from Settings -> Show Logs (send to [email protected])
I also have 2 pieces ST-Link V2 that I can send from Sweden if you think you can help me reproduce the problem.
Email with log file sent.
I think I might have did the app reset. Either way I sent whatever information was there.
@taz Have you tried this? Remove the plastic cover of the FOCBOX and check the points of the USB port, clean it up. Connect it to the PC/MAC using MicroUSB cable and let us know if you are able to get connection detection
Itās also not connecting to Bluetooth. So I would assume itās not the port which is broken. Or can a dirty port influence the connectivity with the Bluetooth module too?
Correct. Itās not the USB.
The problem is not the USB port because then the metr pro module would still work.
@taz Sometimeās when there is an error or any short part on the PCB of the FOCBOX, the settings get reset. So the best way to ensure that is to connect it using USB. I think bluetooth settings are reset. It happens many times.
