I don’t have the pic anymore but someone here has a full aluminum deck with weight holes
I was thinking routing a slot for a thin bar of hard steel down each side and some aluminum plate from the trucks to the steel…it’ll add some weight but it should be offset by the crater for the electronics…I think
Slight issue is it might just split the board into strips under stress
Yeah, it is an aluminum spine built into the board. Functions like a chassis, makes you wonder how you ever lived without it after riding one for awhile. The pro tucker is still considered a longboard but it is tailored for DH racing. There are some older models that are longer but you would have to find one second hand.
I want to be as low to the ground as possible so I’m gonna core out the board and have a super slim enclosure so I don’t get beached everywhere…but that also means my deck is a wooden box and will probably fall apart…I’m wondering how I can get it to stay together
Second it, or rather 3rd or 4th it(as I see few others have suggested the same). If you plan to get a cheaper deck and hollow it out and then reinforce it, then be ready for more surprises. And it might end up costing more…
As Chaka said moonshine tucker pro will be the closest to what he has… there is a cheaper model at 190 bucks…if you want cheap we’ll get use to junk and be ready to replacing that board very often and watch how much you save … your best bet is what @b264 suggest … that is probably the cheapest nice looking deck never mind it’s tallored to eskate…
You digging a hole dude this game isn’t cheap and to do this you need lots of experience be ready to throw the cash away… lol just the cost of materials to ski it is over your budget almost. Never mind tools and deck…
You could make your own deck from ply wood and route out the middle and then add fibreglass. It works I’ve done it, I haven’t had a chance to test it yet though.
Idk how long it will last but it was cheap enough that if it doesn’t work it doesn’t really matter
Here’s a pic, not done yet. I still need to fibreglass, make the lid and finish the DD. Will probs chuck a single belt on there until I finish the dd as it might be a while lol.
