Right and middle buttons reset your “text” screen stats when you hold it for a few seconds while left button toggles your screen type (you only have two set- max is 4 I believe).
Your cable pins that connect from DaVega to your unity’s uart port.
Ahh yes, they are connected.
I don’t remember whether
- Rx to RX
- Tx to TX
Or
- Rx to tx
- Tx to RX
I switched the white and yellow wires at the unity and the screen just showed white.
The information just doesnt seem to be getting through for some reason
Do you at least see your battery voltage on the screen?
No, no info, it lights up correctly but no info at all, just 0.00
One last thing. I assume the white wires to left on the pic aren’t connected to anything while your 4 multi colored wires are connected to the unity.
Edit:
I’m dumb. I think those are for the switches.
Sorry man. I’m out of ideas. The only thing I could think of is to reflash the firmware. It could be corrupted? It could also be that maybe the new unity firmware is not compatible w the current DaVega version?
I’m using vesc6.
Yeah, they are the switches. I continuity checked every cable including switches and all seems good, i dont understand why i get no info :cry
In Vesc tool, you have ppm and Uart enabled right? I didn’t get a confirmation from you earlier.
In the app i set uart mode to 115200 baud, but thats it. Ppm mode is forward/brake. Is there another PPM setting? Should i use the vesc tool? Ive not tried that yet…
Yes. You should check it. Vesc tool.
Cool ok, ill go have a look (optimistic smiley)
I know it’s a given but make sure you use unity’s Vesc tool.
Here right? Which option?
To the left, hit general under app
Yep
